« 1 2 (3)
Re: Twin turbo
From sutho shire
why twin turbo when u can use one big one and get longer pull! thats why tha japenese have single turbo's on GTR skylines !
my advise is 2 get forged pistons get a GT28 and boost tha hell out of it thats what im doing!
Posted on: 2003/6/12 8:42
Re: Twin turbo
What do you mean by saying that a single turbo has a "longer pull"?
Posted on: 2003/6/13 4:17
Re: Twin turbo
From Sydney
Please dont think that i am butting in although i thought that the reason that people use twin turbo set ups was to get longer pull ????
twin turbo set-ups are designed so that the boost is constant through a higher rev are torque range than a single turbo where once it has reached max boost there really isnt a lot more that the engine can do.
With twin or sequential turbo set up, the first turbo is a lot smaller than the second to assist with different boost or intake in different rev ranges ???
Cheers
Peddler
Posted on: 2003/6/13 6:26
Re: Twin turbo
> twin turbo set-ups are designed so that the boost is constant through a [larger rpm range] than a single turbo
Yes. With a big single turbo, you can get a lot of boost at high rpm, but with dual turbo you can get the same AND more boost at lower rpms.
The main reason more turbo cars aren't twin turbo are 1) cost 2) complexity 3) need, for example drag cars don't need low-rpm tractability 4) cost and 5) cost
Posted on: 2003/6/13 7:40
Re: Twin turbo
From Sydney
you forgot 6) cost and 7, 8, 9 and 10) cost.... hehehe
Cheers
Peddler
Posted on: 2003/6/13 7:48
Re: Twin turbo
From Sydney
DVLDAT,
The fastest GTR's in Japan and Aus are Twin Turbo. HKS',Veilside,GTR700,RH9, Munro's, Keir Wilson's are all twin turbo.
Posted on: 2003/6/13 8:11
Re: Twin turbo
From sutho shire
TRU BUT I STILL REKON THAT IF U USE A BIGGER TURBO IT WILL BE JUST THA SAME AS 2 LITTLE ONE'S IF A DIFFERENCE JUST ADD A BIT OF NOS... NOS = FUN!
Posted on: 2003/6/13 9:39
Re: Twin turbo
Not too shy to talk
From Sunny Coast QLD
Hey,
I reckon the T28 roller is the way to go...
I bought one brand new about 3 years ago from ATS in SA for 1500, they are a great upgrade for a ca. They cannot be rebuilt though so you are better off finding one in excellent cond. And for the ca , way to go , a motor that likes to rev....
They cant be to bad as there are two in QLD daily drivers that are doin consistant 10ssss
Posted on: 2003/6/14 15:44
Re: Twin turbo
From Christchurch New Zealand
i believe that nz has the fastest awd nissan skyline in australasia Reece McGregor (heat treatments racing) 8.63 @260kmh (160mph)
Posted on: 2003/6/15 5:18
"If your not living on the edge your taking up too much space" Rod Millen
« 1 2 (3)
