stupid voltage question
From Canberra, Australia
Ok pretty basic question:
How many volts should I be getting off the battery while it is off?
How many while car is running?
How many while car is running with everything going?
Posted on: 2003/6/4 16:10
1971 Datsun 1200 Coupe
A15 Engine. Holley G180 (32/36 Weber). extractors and 2 inch exhaust.
Standard 1200 4 speed with lightened fly wheel and HD clutch
Stanza front struts and brakes.
15x6 CSA Wheels with 195/50 rubber.
Re: stupid voltage question
12 volts, more or less if the battery is fully charged and in good condition.
13.5-14.5 volts, if the regulator is working correctly.
13.5-14.5 volts, if the alternator is big enough for all the stuff you have. If it drops below this only under load, the alternator is probably defective, but it might also be too small. The original 35 amp alternator is fine for most unless you add big lights and super-high-power stereos.
Posted on: 2003/6/4 16:37
geez, mine only had a 25amp alternator, that was pumping out 15 with the lights off and then 11amps with them on.
its now rectified with a big 55amp alternator and new regulator. runs like a dream, just have to reinstall the stereo
Posted on: 2003/6/4 17:14
From Melbourne, Australia
mine makes 15 when running, dunno why but thats higher than ive ever heard before,
Posted on: 2003/6/5 11:54
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Warwick, QLD
Yeah the 35amp alts are crap with big stereo's all my lights and headlights dim with the bass in my coupe, thats even with it turned down, I'm soon to upgrade though with my CA18 alt should be good
Cheers
Damo
Posted on: 2003/6/5 12:39
Drive It Like You Stole It
Every Car Has 500hp In The Wet
Team NEW SKOOL
From Perth Austarlia
wots the 55 amp alt off? is it a straight swap, does the new pulley have the same groove pattern as the original amp?
Posted on: 2003/6/12 7:00
dont know what it is off but it is still a lucas and bolts straight in. pully is different but because its still a lucas, just swaped them over (they were same size just diferent belt setup). All i know is its good
Posted on: 2003/6/12 10:15
From Brisbane
speaking of altornators i got a brand new one like 6months ago... it is a Hitachi but as i didnt know anything about cars then i dint even ask what amp they were putting on.
question is what amp is my ALT? (it is looks bigger than a standard datoo alt)
numbers are: LT150-23b75s
23100-u5802
Posted on: 2003/6/12 11:00
OLD SkOOL POWeR!!! [color=CC0000]"with the sound & smell of twin 40s at full throttle!!!" [/
From Brisbane
could the 75s, be the 75amp?
Posted on: 2003/6/12 11:29
Probably not 75 amp...
I think it is one of the 35 or so amp ones...
Posted on: 2003/6/13 10:51
