Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#21
Re: Where to bolt fuel pumps under coupe
Fenix_Longbow
Posted on: 2008/6/9 11:46
i would clean it out first and then reseal it before that... thats a given
#22
Mildman
Posted on: 2008/6/11 2:05
I've got a filter between surge tank and EFI pump that should cover crap coming out of the carter, or crap coming out of the surge tank....that's the plan anyway.
I've also seen adapters at Pirtek to change from 6mm to 8mm pipe to which are handy. Haven't found out about the fuel filters yet (if you can specifiy different diameters for in and out. If anyone knows that would be good.
#23
1200rallycar
Posted on: 2008/6/11 3:37
why havent you give me a ring.... you know i've done all this before....
there is a better way to return fuel to the tank than the filler... there is a big breather pipe on top of the tank (under the little panel in the boot) t-piece into that fuel tank wont move it's solid mounted i had fuel pumps mounted on top of the tank like you are trying... it worked but really its horrible to install and horrible to prime pumps and stuff you shouldnt need to adapt hose sizes if you have the right fittings on your surge tank and pumps... and if desperate poor hot water from the kettle on a 1/4 hose to get it on a 5/16 etc when i do efi in a coupe again im getting a tank with in tank pump from a hatchback and making it fit under the car the surgetank way is truely horrible from a plumbing, electrical and mounting view point. systems with that many components will always be unreliable as i found out a few times anyway... give us a call for a chat
#24
Mildman
Posted on: 2008/6/11 5:22
rc.....forgot about your experience - just tried to call, I'll give you another call a bit later.
I'd like to do that same (run in tank) - was thinking of getting an alloy drop tank made. Anway I'll talk to you soon.
#25
Mildman
Posted on: 2008/6/23 10:40
#26
Mildman
Posted on: 2008/6/24 8:11
Unless not all coupes have this removable panel to access the breather pipe....or is it inside the wheel arch cavity?
#27
Mildman
Posted on: 2008/6/25 9:33
..still haven't found it - but I see the 1200rc is online...hint hint
#28
1200rallycar
Posted on: 2008/6/25 9:35
what the hell.......
it's not there but its been in every coupe i've ever seen... should be about 4 inch by 6 inch panel around that lump to the right of the tyre wheel well but but it's not
#29
1200rallycar
Posted on: 2008/6/25 9:37
#30
Mildman
Glad it wasn't just me......
