« 1 2 (3) 4 »
Re: Where to bolt fuel pumps under coupe
i would clean it out first and then reseal it before that... thats a given
Posted on: 2008/6/9 11:46
From SE Melbourne
I've got a filter between surge tank and EFI pump that should cover crap coming out of the carter, or crap coming out of the surge tank....that's the plan anyway.
I've also seen adapters at Pirtek to change from 6mm to 8mm pipe to which are handy.
Haven't found out about the fuel filters yet (if you can specifiy different diameters for in and out.
If anyone knows that would be good.
Posted on: 2008/6/11 2:05
Mildman, Datsunless
From Melbourne, Australia
why havent you give me a ring.... you know i've done all this before....
there is a better way to return fuel to the tank than the filler... there is a big breather pipe on top of the tank (under the little panel in the boot) t-piece into that
fuel tank wont move it's solid mounted
i had fuel pumps mounted on top of the tank like you are trying... it worked but really its horrible to install and horrible to prime pumps and stuff
you shouldnt need to adapt hose sizes if you have the right fittings on your surge tank and pumps... and if desperate poor hot water from the kettle on a 1/4 hose to get it on a 5/16 etc
when i do efi in a coupe again im getting a tank with in tank pump from a hatchback and making it fit under the car
the surgetank way is truely horrible from a plumbing, electrical and mounting view point.
systems with that many components will always be unreliable as i found out a few times
anyway... give us a call for a chat
Posted on: 2008/6/11 3:37
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From SE Melbourne
rc.....forgot about your experience - just tried to call, I'll give you another call a bit later.
I'd like to do that same (run in tank) - was thinking of getting an alloy drop tank made.
Anway I'll talk to you soon.
Posted on: 2008/6/11 5:22
Mildman, Datsunless
From SE Melbourne
So I went looking for this panel in the boot - to get to this breather tube - I don't know if I'm blind or its just not there....this is what i was looking at.
Posted on: 2008/6/23 10:40
Mildman, Datsunless
From SE Melbourne
Unless not all coupes have this removable panel to access the breather pipe....or is it inside the wheel arch cavity?
Posted on: 2008/6/24 8:11
Mildman, Datsunless
From SE Melbourne
..still haven't found it - but I see the 1200rc is online...hint hint
Posted on: 2008/6/25 9:33
Mildman, Datsunless
what the hell.......
it's not there
but its been in every coupe i've ever seen...
should be about 4 inch by 6 inch panel around that lump to the right of the tyre wheel well
but
but
it's not
Posted on: 2008/6/25 9:35
1200 Coupe Rallycar
i guess you can still get to the brethear but you'll have to drop the tank
you can see the panel here..... a rusty colour next to the tyre
Posted on: 2008/6/25 9:37
1200 Coupe Rallycar
From SE Melbourne
Glad it wasn't just me......
Mildman, Datsunless
« 1 2 (3) 4 »
