#1 wtd choke cables for sss su's
baldy Posted on: 2008/6/29 10:44
any one know where I can pick up twin choke cable set up from a 180b sss or any sss with the same set up
#2 Re: wtd choke cables for sss su's
revhead001 Posted on: 2008/6/29 10:46
If you have an origional choke cable with a twin outlet that has crap cables you can get them remade.
#3 Re: wtd choke cables for sss su's
baldy Posted on: 2008/6/29 11:11
I have the original 1200 cable only I want to get both chokes working on the su's so I need everything
#4 Re: wtd choke cables for sss su's
revhead001 Posted on: 2008/6/29 12:00
Like the Alfa you can run 2 independant choke cables
#5 Re: wtd choke cables for sss su's
baldy Posted on: 2008/6/29 12:06
yea good idea if I can't find the original choke mechanism may have to go that way or if I know what it looks like my be able to fabricate one
#6 Re: wtd choke cables for sss su's
pepper Posted on: 2008/6/29 12:22
L18_B110 posted this pic a little while ago, im going to do what he has done here as im in the same situation with my twin su's.
it looks very simple and effective.
#7 Re: wtd choke cables for sss su's
1200wag Posted on: 2008/6/30 3:16
Just a thought but you could try places that work on old minis and MGs like the Healey Factory or Link Automotive in Mitcham.
They had a 1 into 2 cable from memory...
#8 Re: wtd choke cables for sss su's
sidedraught Posted on: 2008/6/30 4:56
Try Midel in Sydney or any carby shop should have a twin choke cable.
#9 Re: wtd choke cables for sss su's
denuto Posted on: 2008/6/30 6:23
I got a cable from a motorbike wreckers which had a device that joins onto a single cable and transfers the movement to two cables. Hard to explain, but easy to understand (and use) once you see it. Works a treat. Cost me $10!
If you depsperately want to see it I might be able to take a photo, but I never seem to be home in daylight.
