wtd choke cables for sss su's
From tasmania
any one know where I can pick up twin choke cable set up from a 180b sss or any sss with the same set up
Posted on: 2008/6/29 10:44
Re: wtd choke cables for sss su's
If you have an origional choke cable with a twin outlet that has crap cables you can get them remade.
Posted on: 2008/6/29 10:46
From tasmania
I have the original 1200 cable only I want to get both chokes working on the su's so I need everything
Posted on: 2008/6/29 11:11
Like the Alfa you can run 2 independant choke cables
Posted on: 2008/6/29 12:00
From tasmania
yea good idea if I can't find the original choke mechanism may have to go that way or if I know what it looks like my be able to fabricate one
Posted on: 2008/6/29 12:06
From Tamworth , NSW
L18_B110 posted this pic a little while ago, im going to do what he has done here as im in the same situation with my twin su's.
it looks very simple and effective.
Posted on: 2008/6/29 12:22
From Croydon Victoria Australia
Just a thought but you could try places that work on old minis and MGs like the Healey Factory or Link Automotive in Mitcham.
They had a 1 into 2 cable from memory...
Posted on: 2008/6/30 3:16
'84 ute, A14 on LPG
'72 Sedan Auto parts car
___________________________________________
"Something's rotten in the state of Pistolero"
From sydney
Try Midel in Sydney or any carby shop should have a twin choke cable.
Posted on: 2008/6/30 4:56
From Beautiful Sunny (sic) Melbourne
I got a cable from a motorbike wreckers which had a device that joins onto a single cable and transfers the movement to two cables. Hard to explain, but easy to understand (and use) once you see it. Works a treat. Cost me $10!
If you depsperately want to see it I might be able to take a photo, but I never seem to be home in daylight.
Posted on: 2008/6/30 6:23
