« 1 (2)
Re: help please... whats needed to convert to efi turbo...
From South Africa
here is a list of all the stuff I need for a complete build....
Note, it does not include the distributor mod, if yours is still points, probably be best to get an electronic dizzy.
The List.
main tube 1
runners Al inlet 4
injector pods 8
Tube endcaps 2
welding 20
inlet manifold flange 2
Runners 304SS Inlet 4
silicone rubbers 38mm 4
clamps 38mm T 8
fuel rail 1
Banjo + Bolt 1
T-body 63mm (76mm od) 1
exhaust flange 10mm MS 1
steam bends 42mm MS 16
turbo flange 10mm MS 1
downpipe flange 10mm MS 1
Boost Plumbing 304SS 1
Boost Gauge 1.5bar 1
Fuel Pressure Regulator 1
injectors 440cc (set) CA18DE 1
injector plugs 4
intercooler 1
fuelpump inline 1
Turbo gt1548 Garrett 1
Fuel hose 6
Fuel filter 1
Gotech MX ECU 1
Basic blow off valve 1
vacuum fittings 3
clamps endcap red 10
clamps 50mm T 4
clamps 63mm T 2
clamps 80mm T 1
vacuum Tube PPRE 6
vacuum T push 1
silicone rubbers 50mm 1
silicone rubber 50to63mm 1
silicone rubbers 63to76mm 1
Gasket Turbine inlet 1
Gasket Turbine out 1
Gasket exhaust 1
Ceramic coating Mnfld 1
Powdercoating 1
Posted on: 2008/6/30 10:28
« 1 (2)
