Re: What Battery is required for an A14 in a 1200 Ute?
Oddly enough, I tend to go the other way. I usually install the largest battery that will comfortably fit in the carrier. I work on the principal that should I ever break down, I can still drive it home on the starter.
Well, OK, I lied about the starter.
Within reason, the greater the battery capacity, the less the overall drain when you hit the starter & the less it takes to bring it back up to voltage again.
With a lower voltage drop when under starting loads, there is more voltage available during the cranking period to spin the starter faster & also to fire up the ignition.
Generally speaking, all things being equal, the larger battery should have a longer service life & I like to see if I can get about 4 or 5 years or better from my batteries. So far so good in that department.
The extra weight should not affect performance noticeably in a street car.
Posted on: 2008/7/6 19:02
Love your Datsun.
Treat it well.
Subject Poster Date
     What Battery is required for an A14 in a 1200 ute? who_dat 2008/7/6 11:12
       Re: What Battery is required for an A14 in a 1200 ute? conehead 2008/7/6 11:33
       Re: What Battery is required for an A14 in a 1200 ute? BRUTE 2008/7/6 11:47
         Re: What Battery is required for an A14 in a 1200 ute? sidedraught 2008/7/6 11:58
           Re: What Battery is required for an A14 in a 1200 ute? who_dat 2008/7/6 13:20
             Re: What Battery is required for an A14 in a 1200 ute? reuby_tuesday 2008/7/6 15:21
               Re: What Battery is required for an A14 in a 1200 ute? Dodgeman 2008/7/6 17:17
           Re: What Battery is required for an A14 in a 1200 ute? ddgonzal 2008/7/6 18:38
             Re: What Battery is required for an A14 in a 1200 Ute? Dodgeman 2008/7/6 19:02
               Re: What Battery is required for an A14 in a 1200 Ute? ddgonzal 2008/7/6 19:10
                 Re: What Battery is required for an A14 in a 1200 Ute? who_dat 2008/7/7 11:27
                   Re: What Battery is required for an A14 in a 1200 Ute? Dodgeman 2008/7/8 0:52
