Re: C120 Vanette..Which Engine?
The housing at the rear of the water pump is the "Timing Chain Cover". There are at least two different ones, but they are most likely interchangeable.
Normally you would get the year of the vehicle, and the engine size (either off the Nissan ID plate, or off the engine block -- see). Then order the new part based on Vehicle, Year and Engine.
ID Numbers
For the different types of water pumps, see Water pump
Posted on: 2008/7/12 18:15
Subject Poster Date
     C120 Vanette..Which Engine? Brownie 2008/7/8 1:51
       Re: C120 Vanette..Which Engine? clyons8 2008/7/8 3:19
         Re: C120 Vanette..Which Engine? Matto1kUte 2008/7/8 3:31
         Re: C120 Vanette..Which Engine? ddgonzal 2008/7/12 18:15
       Re: C120 Vanette..Which Engine? DattoFrog 2008/7/12 13:53
