« 1 (2)
Re: Engine trouble
From NZ
scotty01 wrote:
the engine number does end with a (A13 xxxxxx A) and it is definately the same as the bottom picture. so i can assume it is a short block A13, and the A12 crank will interchange?
Assuming the engines been opened up, just measure the stroke of the piston. Should be either 70mm or 77mm (or maybe 82mm).
Posted on: 2008/7/20 10:30
1200 Coupe Racecar, mid-mount A13, C/R 60L g'box.
Previous "Datsuns": B310 sedan worked A13. B310 coupe A14/dogleg 5-spd. 260C sedan, L26, 3-spd man col chng, 6-seater great tow car!. VL wagon, RB30, 5-spd. Nissan Bluebird SSS U13, SR20, 5-spd.[i...
« 1 (2)
