#11 Re: Cylinder Head bolts.
jaimecidpedro Posted on: 2003/6/17 4:41
Excuse my ignorance, but, what is Arp? Seems like a known bolt maker, right? Probably a tip I should learn.
Jaime.____________________________
#12 Re: Cylinder Head bolts.
ddgonzal Posted on: 2003/6/17 7:35
Yes, ARP is probably the most famous bolt maker in the US hot rod aftermarket.
#13 Re: Cylinder Head bolts.
dattoman_1000 Posted on: 2003/6/17 12:55
Marvellous
These appear to be head studs not bolts.
I'm looking for ARP head studs for mine.
Can you read the part # off the box for me please ?
#14 Re: Cylinder Head bolts.
2332owner Posted on: 2003/6/17 15:20
A12 is 202-4202
A14 is 202-4203
#15 Re: Cylinder Head bolts.
2332owner Posted on: 2003/6/17 15:33
They're each around $80 through Summit although the A14 set shows up as an L20 set. Wierd. Are th A14 and A12 head hardware different?
#16 Re: Cylinder Head bolts.
ddgonzal Posted on: 2003/6/18 6:56
There apparently are some differnces, but they might be mostly strength (different torque ratings).
B310 Head bolts:
Short:
A12S PN 11056-H1000 (van)
A12S, A13, A14S, A15 PN 11056-H2301
Long:
A12S PN 11059-H5000 (van)
A12S, A13, A14S, A15 PN 11059-H5700
I think the "long" bolt is the center bolt.
I'm not sure the difference between the two part numbers for A12S (carbureted motor). Both are listed for B310s.
Here are the B110 head bolts:
A12 11506-H1000
A12 11056-18000
A12 GX 11056-H2301
A12 GX 11056-H2300
A12 11057-18000
A12 11057-H1000
A12 GX 11057-H2300
A12 GX 11057-H2301
« 1 (2)
