throw out bearings
looking at replacing a noisy 56a 4 speed with 60a 4 speed. Are the throw out bearings the same and gear box x members?
Any thing i have to look out for
Posted on: 2008/7/23 13:05
Re: throw out bearings
From SE Melbourne
Pretty sure crossmembers are different - the 60 series I bought had a custom crossmember on it to bolt up to a 1200 - so I assume the std xmember probably doesn't bolt up....
Posted on: 2008/7/23 14:19
Mildman, Datsunless
Yes, crossmembers are different.
Throwout bearing is the same
Throwout bearing carrier may be different, depending on the car and engine it came out of.
Details: 60-Series Transmission, see 5-speed swap notes, crossmember for 4-spped or 5-speed is the same
Posted on: 2008/7/23 19:28
From The garage, NZ
what a series is it? I found a 60a would bolt up to a late a12 with the original a12 carrier and bearing no worries (this is the smallest carrier).
Posted on: 2008/7/23 21:48
From NZ
As alluded by Cheater, the carriers are interchangeble between boxes.
Lengths (throw) varies to suit Flywheel thickness (bigger engines have thicker flywheels as standard at least). Forks also differ.
Suck it and see!
Posted on: 2008/7/24 11:07
1200 Coupe Racecar, mid-mount A13, C/R 60L g'box.
Previous "Datsuns": B310 sedan worked A13. B310 coupe A14/dogleg 5-spd. 260C sedan, L26, 3-spd man col chng, 6-seater great tow car!. VL wagon, RB30, 5-spd. Nissan Bluebird SSS U13, SR20, 5-spd.[i...
