« 1 2 3 4 (5) 6 7 »
#41 Re: !!a15 TURBO!!
roddat Posted on: 2008/7/26 0:14
hi, i've ran an l series (same princable though) with a blow through system scince 2001 with a sc14 s/c. the teflon has held up at 10psi. i use the car for burnout comp's so it get's really hot. also i run twin webber's that came off a factory blow through turbo masarati. you'll need to use a rising rate fuel reg and keep your fuel presure about 4-5 psi above your boost presure.
#42 Re: !!a15 TURBO!!
roddat Posted on: 2008/7/26 0:24
oh by the way the rising rate reg that i have, i actually made my self. all it is is a holly blue reg with the adjuster screw drilled out and a peice of tube silver soldered to the end of the screw. because it is about 1square inch, when it see's 1psi of boost it give's you 1 more psi of fuel preasure. it work,s well!!
#43 Re: !!a15 TURBO!!
SLAM1024 Posted on: 2008/7/26 0:45
I am building an A12 turbo setup with an SU turbo carb and turbo from an MG Metro .. same engine as the mini but turbo 1.3l
Should be getting very close to being finished by the end of summer.
#44 Re: !!a15 TURBO!!
TYR-33D Posted on: 2008/7/29 11:30
would i use a carter black electric high pressure fuel pump????
#45 Re: !!a15 TURBO!!
TYR-33D Posted on: 2008/7/29 12:04
and what fuel pressure regulator would i use??
#46 Re: !!a15 TURBO!!
A14force Posted on: 2008/7/30 6:54
How much fuel pressure does that supply at idle, or cruise throttle? Do you run your TB before or after the supercharger?
#47 Re: !!a15 TURBO!!
TYR-33D Posted on: 2008/8/5 11:10
any one????????????????????
#48 Re: !!a15 TURBO!!
steveo Posted on: 2008/8/5 11:14
Go for a good Quality one, like a malpassi rising rate, got mine on the weekend off a mate for cheap, buy a new one from a repratable dealer and you can't go wrong!
#49 Re: !!a15 TURBO!!
TYR-33D Posted on: 2008/8/5 11:22
wat would i hav to ask for??
#50 Re: !!a15 TURBO!!
steveo Posted on: 2008/8/5 11:25
Ask for a Malpassi rising rate fuel regulator, might be a bit pricey but you get what you pay for, they might have some other brands depend on where you go, just ask around for a good quality fuel reg
« 1 2 3 4 (5) 6 7 »
