« 1 (2)
Re: Black Spark Plugs (A12)
From adelaide hills
the choke plate is open when the choke is all the way in
i just replaced the plugs which are bp5es (and gapped them)
and they are dry and sooty
also at idle when the engine is warm no choke, fuel spits out the exhaust.
Posted on: 2008/7/29 8:57
1977 1200 ute aka franky weekender
1979 sunny wagon aka rod the second daily
From Adelaide, Australia
Another pretty common carb fault;
Can you stall the engine with the mix screw, carefully screw it in and when it leans out enough it should stall, if it doesnt stall someone may of wound it hard all the way in and damaged the end which will cause rich idle. If it does stall you can eliminate that issue and wind back out to where it was originally. Then start looking at float level etc.
Do you have a manual?
Posted on: 2008/7/29 9:02
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
From adelaide hills
dont have a manual
and its pissin here at the moment so....
when i adjust the mixture it begins to die but ive never screwed it right in.
i also looked on the id plate and there is nothing there? (on the carby)
Posted on: 2008/7/29 9:09
From Aust
My advice...
Your running to rich in you mixture and your timing may be out causing incorrect burning of the fuel/air mixture leaving carbon deposits in the chamber.
My advise would be to give her a good tune up once over and as stated above it will reward you in many ways.
Cheers
Posted on: 2008/7/29 11:37
From adelaide hills
my step parent person rang sprint 2 day and they said it sounds like a crappy carby
him and a mate got the compressor onto it and re adjusted the timing
now she runs good
ill clean the sparkys 2morro and see if they go black, hopefully not
if they do
Posted on: 2008/7/30 11:19
From adelaide hills
took the plugs out this arvo
and they were clean YAY
thanks for all the help people!
Posted on: 2008/7/31 9:22
« 1 (2)
