Fandatstick wrote:
Seems to be a common misconception that sidedrafts somehow go out of tune over time.
Once they're set up properly (Dyno to ensure correct jets etc) there's not much to go out of tune unless the idle mixture or balance is fiddled with or engine spec is changed.
A Dyno is not necessary to re-set idle mixture and balance - just need someone who knows what they're doing.
Fandatstick is right, particularly the last eight words.
Once the carbs have been correctly jetted, & remember that they are fixed jets, not adjustable, then it's a done deal.
The only things that can possibly go 'off tune' are the float levels, [almost totally unheard of], the idle mixture, usually because some dickhead fiddles with them, & the balance between the carbs, usually due to poor quality linkages, or loose fasteners allowing adjusting parts to vibrate & move around.
Hell, Ferraris, Maserattis, Valiant Chargers & several others used multiple sidedraught Webers as standard & these cars are not known for chronic out-of-tune carb problems.
I also agree with Sidedraught when he says that a couple of 40's will work much better on the street than 45's & in my personal view, a single carb will be a much better proposition from a driveability viewpoint as well as an economic one. At least it eliminates the 'balance between carbs' problem.
Unfortunately a single carb does not have the same WOW factor that duals have when you open the bonnet.
Overall, as long as you have a sound instalation, with quality parts & your fuel is properly filtered [I prefer a big filter at the tank & a small one in the engine bay] then any Weber sidedraught that is in good, sound condition should deliver the same reliability as the original Hitachi.
The colour tune plugs seem to be OK for setting the idle mix in a stock engine, they won't be of much help in an engine that has a lumpy cam as the idle mixture in these can be all over the place.
They are also not much help in 'off idle' mode as you really want to see what the mix is at speed & under load & the law frowns on driving around with a mechanic under the bonnet.
