Re: Watery Oil leaking from the Crank Case
From Aust
Condensation will only go milky around the oil filler cap not through out the whole crank case.
Sounds like a blown head gasket. Have you been loosing coolant lately??
When you say the car has been playing up does this mean a miss when you start it up or hard to start?
This is something that needs attention straight away or you will do more damage to the motor.
Cheers
Posted on: 2008/7/31 4:10
Subject Poster Date
     Watery Oil leaking from the Crank Case morrieturbo 2008/7/31 3:43
       Re: Watery Oil leaking from the Crank Case 1000Coupe 2008/7/31 3:53
       Re: Watery Oil leaking from the Crank Case 1200rallycar 2008/7/31 3:54
         Re: Watery Oil leaking from the Crank Case morrieturbo 2008/7/31 4:11
           Re: Watery Oil leaking from the Crank Case snap_point 2008/7/31 4:14
             Re: Watery Oil leaking from the Crank Case morrieturbo 2008/7/31 4:17
               Re: Watery Oil leaking from the Crank Case snap_point 2008/7/31 4:21
                 Re: Watery Oil leaking from the Crank Case 1000Coupe 2008/7/31 5:38
       Re: Watery Oil leaking from the Crank Case snap_point 2008/7/31 4:10
