Re: Stroked A14, decreasing the stroke
From sydney australia
I believe a couple of speedway engines were built for the compact speedcar class which had a 1400 cc limit, that were A14's with an A12 crank & bored out to 79 mmm resulting in a 1400 cc screamer engine.Not sure what conrods you'd use to make up for the decreased stroke, probably a set of custom conrods would be needed. Thats all I know, maybe somebody else has more information.
Posted on: 2008/8/9 9:14
Subject Poster Date
     Stroked A14, decreasing the stroke Clive 2008/8/9 8:14
       Re: Stroked A14, decreasing the stroke b310gx 2008/8/9 9:14
         Re: Stroked A14, decreasing the stroke Clive 2008/8/9 9:36
           Re: Stroked A14, decreasing the stroke b310gx 2008/8/10 1:33
             Re: Stroked A14, decreasing the stroke Mildman 2008/8/10 7:43
               Re: Stroked A14, decreasing the stroke Clive 2008/8/10 9:02
