#1 WRECKING A SUNNY
bobthebuilder Posted on: 2008/8/10 2:14
Hi Guys
I have the opportunity to strip a Sunny before it goes to the crusher.What bits do I grab ?
Are the struts the same as a 120y ?
Is the gearbox a 60a ?
What other bits are worthwhile salvaging?
Thanks
Bob
#2 Re: WRECKING A SUNNY
cheater_5 Posted on: 2008/8/10 2:19
gearbox depends on what size engine it has.
Get the drive train
The struts can be fitted to 1200's using a few other parts but not the same as 120y.
#3 Re: WRECKING A SUNNY
bobthebuilder Posted on: 2008/8/10 2:23
Its a smokey 1200 so im assuming its a 60a.
It has air. Can this be adapted to a 1200 ?
Thanks
Bob
#4 Re: WRECKING A SUNNY
SRB310 Posted on: 2008/8/10 3:54
If you can't use the A/C parts I wouldn't mind taking them off your hands! Is it a round or square front?
#5 Re: WRECKING A SUNNY
lethal_john Posted on: 2008/8/10 5:09
Has it got a brake booster? i'll grab it if its compatible with my 1200
#6 Re: WRECKING A SUNNY
cheater_5 Posted on: 2008/8/10 7:32
im not 100% but if its an a12, it should have the 56A behind it. A14 and A15 should have the 60a in 4speed and the SGX model having the 60A 5 speed. Some where in there the 60L came in, i think behind some a14's. Im basing this on the factory deciding the a14 and a15 having to much torque for the 56A. Remember the 56A (not to be confused with 56) is a bit stronger than the 56 and came behind b120's and b122's.
Correct me if im wrong, im sure someone will
