Re: multi coil ignition a15
From perth
if you fit magnets to the flywheel you just drill a hole in the right spot (ie: TDC ) and press in a magnet as per holden black 6 cyl.
number of magnets required depends on what signal ecu wants ,usually half the no of cyls
pick up disc on the balancer is easier but is more exposed
if you need to adjust sensor position maybe better on the front (some computers want TDC position, some want initial timing )
you could use a dissy for a signal
dazza
Posted on: 2008/8/16 8:52
Subject Poster Date
     multi coil ignition a15 rock1200 2008/8/16 5:44
       Re: multi coil ignition a15 TUF-110 2008/8/16 6:21
         Re: multi coil ignition a15 dazza1200 2008/8/16 7:49
           Re: multi coil ignition a15 rock1200 2008/8/16 8:08
             Re: multi coil ignition a15 Curtis 2008/8/16 8:22
               Re: multi coil ignition a15 dazza1200 2008/8/16 8:52
                 Re: multi coil ignition a15 PIGDOG 2008/8/16 9:03
                   Re: multi coil ignition a15 rock1200 2008/8/16 17:15
                     Re: multi coil ignition a15 dazza1200 2008/8/23 10:02
                       Re: multi coil ignition a15 rally1200 2008/8/23 11:18
                         Re: multi coil ignition a15 frankthedolphintrainer 2008/8/23 11:25
                           Re: multi coil ignition a15 rock1200 2008/8/24 2:57
                             Re: multi coil ignition a15 frankthedolphintrainer 2008/8/24 3:24
                               Re: multi coil ignition a15 PIGDOG 2008/8/24 12:39
                                 Re: multi coil ignition a15 dazza1200 2008/8/28 11:54
                                   Re: multi coil ignition a15 PIGDOG 2008/8/28 12:07
                                     Re: multi coil ignition a15 rock1200 2008/8/28 12:41
                                       Re: multi coil ignition a15 PIGDOG 2008/8/28 12:44
                                         Re: multi coil ignition a15 rock1200 2008/8/28 12:56
                                           Re: multi coil ignition a15 Retal052 2008/8/28 13:59
                                             Re: multi coil ignition a15 reuby_tuesday 2008/8/28 14:45
                                             Re: multi coil ignition a15 rock1200 2008/8/29 4:15
                                               Re: multi coil ignition a15 PIGDOG 2008/8/29 4:24
                                               Re: multi coil ignition a15 Retal052 2008/9/1 15:25
                                                 Re: multi coil ignition a15 Dodgeman 2008/9/1 15:35
                                                   Re: multi coil ignition a15 reuby_tuesday 2008/9/1 21:16
                                                     Re: multi coil ignition a15 sikyne 2008/9/2 0:03
                                                       Re: multi coil ignition a15 gillie 2008/9/3 14:11
                                                         Re: multi coil ignition a15 Retal052 2008/9/8 10:04
                                                           Re: multi coil ignition a15 tiagosainhas 2008/10/15 15:13
                                                           Re: multi coil ignition a15 Retal052 2008/10/16 10:58
                                                             Re: multi coil ignition a15 1200rallycar 2008/10/16 11:32
                                                               Re: multi coil ignition a15 frankthedolphintrainer 2008/10/16 11:41
                                                             Re: multi coil ignition a15 LONGBROW 2008/10/16 12:02
                                                               Re: multi coil ignition a15 D 2008/10/16 12:30
        Re: multi coil ignition a15 datto1000wagon 2008/10/16 12:46
        Re: multi coil ignition a15 Retal052 2008/10/17 13:17
        Re: multi coil ignition a15 dazza1200 2008/10/17 13:43
        Re: multi coil ignition a15 D 2008/10/17 14:33
        Re: multi coil ignition a15 Retal052 2008/10/23 13:45
                                                 Re: multi coil ignition a15 Retal052 2008/9/1 15:53
