Re: what has the same axel as a h165
From sydney australia
that's definitely a h165 housing in the photo,exactly the same as one i just swapped to a mate for a race seat & some rear shocks.i always usd to put studs in,usually from the h145 housing i was pulling out,as i didn't want to strip threads in the housing through constant diff swaps.torque setting - strip thread then 1/2 turn back.
Posted on: 2003/6/20 13:42
From Melbourne AUS
ahhh just what i wanted to hear......
anyone know a good oil to use in them?
and how much?
Posted on: 2003/6/20 14:39
1973 B110 A12
Use 90w oil. Fill it up until it runs out the filler hole, that's the proper level.
Posted on: 2003/6/20 20:10
From Melbourne AUS
so how much is a H165 worth? in good working order?
Posted on: 2003/6/21 7:42
1973 B110 A12
more on the differential oil question.
90w is used for temperatures of 0-40 Celsius (32-104 F) per Nissan
If you live in a place with a wider temperature range, a multi-weight oil could be used like maybe 50w-140 (?).
If you have a limited slip diff (LSD) you need to add an additive to the oil per the recommendation of the LSD maker.
Posted on: 2003/6/21 7:50
« 1 2 (3)
