Re: CA18 pinging problem
heh kegs
"Even gave it subaru upper engine cleaner."
It almost has to be an N/A bottom end. I had a fresh 8.5:1 comp ratio FJ20 that had 165psi over all four.
Someone must know of a definitive way to tell a turbo block from the outside. If not I think only the DET's had oil squirters on the pistons.
Also is there any evidence of tampering with the oil feed for the turbo as well as the water return?
Posted on: 2008/8/20 9:34
Subject Poster Date
     CA18 pinging problem ogyris 2008/8/20 0:10
       Re: CA18 pinging problem tappet 2008/8/20 1:08
         Re: CA18 pinging problem ogyris 2008/8/20 3:09
         Re: CA18 pinging problem ogyris 2008/8/20 3:10
           Re: CA18 pinging problem 1000Coupe 2008/8/20 3:50
             Re: CA18 pinging problem matty 2008/8/20 4:05
               Re: CA18 pinging problem ogyris 2008/8/20 5:51
                 Re: CA18 pinging problem Tyrie 2008/8/20 6:18
                   Re: CA18 pinging problem crzy_1200_ute 2008/8/20 8:47
                     Re: CA18 pinging problem kegs 2008/8/20 9:04
                       Re: CA18 pinging problem Daveman 2008/8/20 9:34
                         Re: CA18 pinging problem dattodude 2008/8/20 11:31
                           Re: CA18 pinging problem ogyris 2008/8/20 12:07
                         Re: CA18 pinging problem ogyris 2008/8/20 11:49
