« 1 (2)
Re: 6 cylinder conversions
ZigZag wrote:
because of my stupid electrical problem i am thinking of either tearing all the wiring out and having an auto elect put all new stuff in or taking the ute off the road and doing some kinda conversion.... the holden v6 conversion looks tempting are there any other rear wheel drive 6 cylinders that may fit in?
You have an electrical problem that you can't seem to fix, so you want to tackle a dead end project with a six cylinder conversion instead.
Now why didn't I think of that.
Posted on: 2008/8/22 2:02
Love your Datsun.
Treat it well.
From Geelong, Vic
hahaha thats gold, its takes about a half hour to change the dash and engine loom in a 1200. takes alot longer to do a full engine conversion and then also change both looms and modify them to run the new engine
and why in the hell would you put a 6 cylinder in a 1200 for a road car, ive your going to kill the handling and have no chance of rego or engineers why not go a v8?
Posted on: 2008/8/22 2:24
From newcastle, NSW
Tearing out all the wiring??? thats a bit of overkill isn't it? there would only be a minor problem with the wiring, it doesn't take much for something to go wrong when it comes to electrics. My advice is take it to auto electrics place shouldn't cost that much to fix, couple of hundred at the most. If you don't want to get it towed, look in the yellow pages, and see if you have a mobile auto elec in your area.
You have a starter motor problem from memory? take the starter motor out, and take that to your local auto elec he should be able to test it, if its not that you have to get the wiring and relays looked at.
Don't give up! if we all gave up when we faced difficulties we would all be walking everywhere.
From Perth WA
benddatsun wrote:
why not a VG30 out of 80s 300 zed?
maybe a good idea, the dimensions are huge tho , fills the engine bay in a big Nissan Cedric. I knew of one in a 720. they drink like a V8, but bulletproof internals can support huge hp.
Posted on: 2008/8/22 3:20
From Geelong, Vic
think your talking about a VG30de, single cam ones arent that big
i was meaning at the very most change both wiring looms, which isnt a huge job
Posted on: 2008/8/22 4:56
From perth
there is a vg30e (sohc) in a 120y drag racing in perth. there is plenty of room looks like it was born in there.
datto only has half a dozen wires if you cant sort that out your never going to get a conversion finished
dazza
Posted on: 2008/8/23 9:40
Not too shy to talk
From adelaide
i have the 1200 ute from murray bridge......
Posted on: 2008/11/16 14:41
« 1 (2)
