Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
Are pintara & r31 diffs the same?
lethal_john
Posted on: 2008/8/24 2:12
Hii guys, are pintara and r31 diffs the same? if there not are the pintara's still a strong diff? thanks in advance for any help
#2
Re: Are pintara & r31 diffs the same?
dattodude
Posted on: 2008/8/24 2:14
for a 1200 either is fine.
The skyline diff is a 28 spline 4 pinion (same as used on Commodore V8 and rb30et) 3.7/3.9:1 The pintara diff is a 25 spline 2 pinion (same as used on Commodore VL 6 cyl). 3.9/4.1:1
#3
lethal_john
Posted on: 2008/8/24 2:55
do you reckon it will handle a fair bit of hp?
#4
revhead001
Posted on: 2008/8/24 6:39
It's not the HP it's the torque. They will handle anything an A series will dish out. Or even an Sr. Use the 28 spline as it makes it easier for LSD options.
#5
PIGDOG
Posted on: 2008/8/24 12:53
25 spliners have LSDs too...just most of them suit the nice 2.7:1 performance gearsets
#6
revhead001
Posted on: 2008/8/24 13:24
You can make a 25 spline 4 pinion lsd using the side gear and cone from a standard 25 spline lsd but it is alot easier to stick with the 28.
