« 1 (2)
Re: What is the procedure to bleed clean hydrolic fluid system?
From hastings,vic
i use a sealed container with two hoses in the top of the container also sealed, one hose 500mm other hose 2-3mt, long enough to reach a vacum line on the motor,short hose on the cracked nippel start car and suck the fluid thru,repeat all wheels, longest to shortest.
Posted on: 2008/8/25 11:26
From South Africa, Bloemfontein
I have another idea that sounds about the same. I want to buy one of those biga$$ syringes that they use to inject cows and big farm animals.Put it on the 500mm hose,connect the other point on the bleed nipple.Loosen the nipple and pull on the syringe to cause a vacuum.This I think will also suck out the fluid and I just have to fill the top with new fluid.
Posted on: 2008/8/25 11:31
1977 Datsun 1200GX
From hastings,vic
same idea but useing car vucum is easyer.
Posted on: 2008/8/25 11:35
From Adelaide, Australia
The pressurised bleeders can cause damage to seals, there are no shortcuts but to do things properly, thats one person at the bleed nipple and one on the pedal. Although on my clutch I can reach pedal with my left hand and bleed nipple with right hand that works well but that clutch pedal is hard to push!
Posted on: 2008/8/25 11:57
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
« 1 (2)
