« 1 (2) 3 4 5 ... 7 »
Re: Biggest engine in 1000
From Wagga Wagga
Yeah Put some concrete powder on ya Weeties and Harden Up
what about the V6?
Posted on: 2008/8/26 10:43
1980 Datsun 1200 Ute (WIP)
A15 Engine
5 Speed Sunny
H165 Diff
From perth airport
READ THE FIRST POST
wats the biggest that can be regoed
Posted on: 2008/8/26 11:19
perth airport parking
Datsun 1200 ute A14
hahaha revhead has more emotiocons
Posted on: 2008/8/26 11:27
From Sydney
1.6 liter turbo is the biggest you can got ie 4agze 4agte b6t mx5 motor with turbo as i am doing (Warning dont do it it to much work lol)
Posted on: 2008/8/26 12:04
From Penrith, Sydney, NSW
Hmmmm 4agte 1000. Sounds good.
The main reason for asking is i have found a wicked little 1000 sedan with all the hard work done and just screaming for an engine conversion to finish her off.
Now all i have to do is convince the current owner to sell it to me for the price that i want to pay!!!!
Trav
Posted on: 2008/8/26 12:14
"If the doors of perception were cleansed, every thing would appear to man as it is......infinite"
28cm wide and 45 cm long Transwarp 11 electric motor,
1000 lbs of torque no gearbox,
no transmission or tunnel changes
just two piece tailshaft with support,
150kg of lithium batteries,
11 second quarter mile,
60-100 klm range with short recharge times with onboard charger.
Keep your original gearbox mounts, keep your original a10 running gear in the shed.
Invest in all alloy Winters quickchange rear end, flip the lid at the back and change ratio for the track then flip it back for the road.
5 cents per 100klm of combined battery and electricity costs.
Just an alternative to think about.
Posted on: 2008/8/26 12:19
From Sydney
dont got b6 motor problem is that the sump might hit the cross member requires mods then u got the tunnel fabrocation and lining up to tail shaft to all fit and then drag link to fit then bonnet ahhhhhhhhhhhh but maybe its easier with a 4age or a series
Posted on: 2008/8/26 12:28
From Darwin NT
do a coilover shock conversion and then you can cut up that crossmember up as much as you want
Posted on: 2008/8/26 12:35
current project 4x4 patrol...
And all for the low low price of around $20K installed!
Posted on: 2008/8/26 12:47
From Perth WA
Bah just keep a A series in it! Mine has enough trouble keeping traction with a mild A15 and 205s! Mild meaning NO headwork!
And that way you dont ruin the best aspect of the 1000... the light weight!
Posted on: 2008/8/26 12:55
Chris...
