« 1 (2) 3 4 5 ... 7 »
#11 Re: Biggest engine in 1000
Burke_a_lot Posted on: 2008/8/26 10:43
Yeah Put some concrete powder on ya Weeties and Harden Up
what about the V6?
#12 Re: Biggest engine in 1000
perthute Posted on: 2008/8/26 11:19
READ THE FIRST POST
wats the biggest that can be regoed
#13 Re: Biggest engine in 1000
Posted on: 2008/8/26 11:27
hahaha revhead has more emotiocons
#14 Re: Biggest engine in 1000
Tommo1200 Posted on: 2008/8/26 12:04
1.6 liter turbo is the biggest you can got ie 4agze 4agte b6t mx5 motor with turbo as i am doing (Warning dont do it it to much work lol)
#15 Re: Biggest engine in 1000
Trav Posted on: 2008/8/26 12:14
Hmmmm 4agte 1000. Sounds good.
The main reason for asking is i have found a wicked little 1000 sedan with all the hard work done and just screaming for an engine conversion to finish her off.
Now all i have to do is convince the current owner to sell it to me for the price that i want to pay!!!!
Trav
#16 Re: Biggest engine in 1000
D Posted on: 2008/8/26 12:19
28cm wide and 45 cm long Transwarp 11 electric motor,
1000 lbs of torque no gearbox,
no transmission or tunnel changes
just two piece tailshaft with support,
150kg of lithium batteries,
11 second quarter mile,
60-100 klm range with short recharge times with onboard charger.
Keep your original gearbox mounts, keep your original a10 running gear in the shed.
Invest in all alloy Winters quickchange rear end, flip the lid at the back and change ratio for the track then flip it back for the road.
5 cents per 100klm of combined battery and electricity costs.
Just an alternative to think about.
#17 Re: Biggest engine in 1000
Tommo1200 Posted on: 2008/8/26 12:28
dont got b6 motor problem is that the sump might hit the cross member requires mods then u got the tunnel fabrocation and lining up to tail shaft to all fit and then drag link to fit then bonnet ahhhhhhhhhhhh but maybe its easier with a 4age or a series
#18 Re: Biggest engine in 1000
datto1000wagon Posted on: 2008/8/26 12:35
do a coilover shock conversion and then you can cut up that crossmember up as much as you want
#19 Re: Biggest engine in 1000
revhead001 Posted on: 2008/8/26 12:47
And all for the low low price of around $20K installed!
#20 Re: Biggest engine in 1000
beattie Posted on: 2008/8/26 12:55
Bah just keep a A series in it! Mine has enough trouble keeping traction with a mild A15 and 205s! Mild meaning NO headwork!
And that way you dont ruin the best aspect of the 1000... the light weight!
