Ohm range of 1200 temp sender?
From Brisbane
Hey guys,
my temp sender is stuffed on my CA 1200 and i'm trying to track down a sender maybe from vdo or similar that will be compatible with the 1200 gauge and also screw in to the CA housing.
Any ideas?
justin
Posted on: 2008/8/26 3:10
Re: Ohm range of 1200 temp sender?
As measured by club members, by moving the float up and down from stop to stop:
12 ohms fully up
88 ohms fully down
datsun1200 club article Fuel Tank
Posted on: 2008/8/26 4:23
From Brisbane
Yes that's true, but i was after the temperature sender ohm range, not the fuel sender range...
Posted on: 2008/8/27 22:52
Sorry about that. I dont recall hearing about any measurements for temp sender. If you have an ohmmeter, you can measure it. Measure the sensor when cold, then when the engine is fully warmed up.
Posted on: 2008/8/28 3:56
