Re: multi coil ignition a15
From Adelaide
my computer has four ingnition outputs, it takes the signals from the hall effect sensor and works it out.
Posted on: 2008/8/28 12:56
XR6T 320rwkw
Stock 1200 Sedan
1200 Sedan, S/C a15
Subject Poster Date
     multi coil ignition a15 rock1200 2008/8/16 5:44
       Re: multi coil ignition a15 TUF-110 2008/8/16 6:21
         Re: multi coil ignition a15 dazza1200 2008/8/16 7:49
           Re: multi coil ignition a15 rock1200 2008/8/16 8:08
             Re: multi coil ignition a15 Curtis 2008/8/16 8:22
               Re: multi coil ignition a15 dazza1200 2008/8/16 8:52
                 Re: multi coil ignition a15 PIGDOG 2008/8/16 9:03
                   Re: multi coil ignition a15 rock1200 2008/8/16 17:15
                     Re: multi coil ignition a15 dazza1200 2008/8/23 10:02
                       Re: multi coil ignition a15 rally1200 2008/8/23 11:18
                         Re: multi coil ignition a15 frankthedolphintrainer 2008/8/23 11:25
                           Re: multi coil ignition a15 rock1200 2008/8/24 2:57
                             Re: multi coil ignition a15 frankthedolphintrainer 2008/8/24 3:24
                               Re: multi coil ignition a15 PIGDOG 2008/8/24 12:39
                                 Re: multi coil ignition a15 dazza1200 2008/8/28 11:54
                                   Re: multi coil ignition a15 PIGDOG 2008/8/28 12:07
                                     Re: multi coil ignition a15 rock1200 2008/8/28 12:41
                                       Re: multi coil ignition a15 PIGDOG 2008/8/28 12:44
                                         Re: multi coil ignition a15 rock1200 2008/8/28 12:56
                                           Re: multi coil ignition a15 Retal052 2008/8/28 13:59
                                             Re: multi coil ignition a15 reuby_tuesday 2008/8/28 14:45
                                             Re: multi coil ignition a15 rock1200 2008/8/29 4:15
                                               Re: multi coil ignition a15 PIGDOG 2008/8/29 4:24
                                               Re: multi coil ignition a15 Retal052 2008/9/1 15:25
                                                 Re: multi coil ignition a15 Dodgeman 2008/9/1 15:35
                                                   Re: multi coil ignition a15 reuby_tuesday 2008/9/1 21:16
                                                     Re: multi coil ignition a15 sikyne 2008/9/2 0:03
                                                       Re: multi coil ignition a15 gillie 2008/9/3 14:11
                                                         Re: multi coil ignition a15 Retal052 2008/9/8 10:04
                                                           Re: multi coil ignition a15 tiagosainhas 2008/10/15 15:13
                                                           Re: multi coil ignition a15 Retal052 2008/10/16 10:58
                                                             Re: multi coil ignition a15 1200rallycar 2008/10/16 11:32
                                                               Re: multi coil ignition a15 frankthedolphintrainer 2008/10/16 11:41
                                                             Re: multi coil ignition a15 LONGBROW 2008/10/16 12:02
                                                               Re: multi coil ignition a15 D 2008/10/16 12:30
        Re: multi coil ignition a15 datto1000wagon 2008/10/16 12:46
        Re: multi coil ignition a15 Retal052 2008/10/17 13:17
        Re: multi coil ignition a15 dazza1200 2008/10/17 13:43
        Re: multi coil ignition a15 D 2008/10/17 14:33
        Re: multi coil ignition a15 Retal052 2008/10/23 13:45
                                                 Re: multi coil ignition a15 Retal052 2008/9/1 15:53
