« 1 2 3 (4) 5 »
Re: L18 V CA18
I considered L16 as wellbut L18 won cause the L16 i found was younger than the car, a no no for engine swaps in vic.
They are of similar power anyway and torque, L16 with a bit of work should rev higher due to (if my memoery is right) slightly shorter storke.
Posted on: 2008/8/29 8:59
Re: L18 V CA18
From Armidale N.S.W
Oh so like polution gear or something ? Cause L16 came out in 1600 so wouldnt need polution gear would ya ? I found a complete stanza 4 speed today.
Posted on: 2008/8/29 9:02
73 1200 wagon SOLD
Re: L18 V CA18
From Darwin NT
L16's also came in stanzas dont forget
Posted on: 2008/8/29 9:17
current project 4x4 patrol...
Re: L18 V CA18
From Armidale N.S.W
Yeah thats what i was getting at. when i said i found a stanza and im going L16.
Posted on: 2008/8/29 9:23
73 1200 wagon SOLD
Re: L18 V CA18
From tasmania
Tassie law is the motor can be later than the car it is going in, but the motor can't be earlier.
Posted on: 2008/8/29 10:42
Re: L18 V CA18
I can't imagine why, as long as the engine conforms to all the relevant regulations regarding emissions that relate to the newer model chassis that the older engine is to be used in.
We can now update old engines with PCV systems, modern carb[s] or EFI, & Electronic ignition or even LPG without difficulty, exceding the requirements of an original engine by a wide margin, so where's the problem.
Hell, if we can get an early Hemi or Flathead Ford to run clean, then anything can be fixed.
Posted on: 2008/8/29 11:44
Love your Datsun.
Treat it well.
Re: L18 V CA18
From tasmania
my engineer asked me what year the L18 I'am putting in was . He said an earler motor transport wont allow it That seams strange you can fit 2008 model motor in a 1970 car but you can't fit a 1969 .mmm.
Posted on: 2008/8/29 12:23
Re: L18 V CA18
From Darwin NT
what is the go with older engines into pre ADR compliant cars such as the 1000 in your area (tas??)
Posted on: 2008/8/29 12:31
Re: L18 V CA18
From tasmania
I'll try to find out next time Ia'm talking to my engineer .I know when I applied to the transport to run the L18 in the 1200 I had to do a 7 page essay on it just to get a preliminary approval .
Posted on: 2008/8/29 12:45
Re: L18 V CA18
lucky my car is 73 and engine is out of a may 74 car, jul 74 saw more emissions crap so scrape in with just a pcv valve , done and done! got one already (got 2 but will take catch can off for all of it)
Posted on: 2008/8/29 12:47
« 1 2 3 (4) 5 »
