« 1 (2)
#11 Re: Help removing windsheild....
DatsAndy Posted on: 2008/8/31 21:32
So in a word: Be patient. That's 2 words isn't it ? But good advice none the less.
#12 Re: Help removing windsheild....
Ronny_CTS Posted on: 2008/9/2 21:18
Guys...i had the most brilhant idea....
I was looking at the windsheild...and i was afraid of forcing it to much...and out of nowhere it hit me......PENCILS!!!!
I had a pack of 25 chinese pencils that cost me 99 cents and this is what i imagened...
The photo is pretty crappy...so let me explain...the easiest way to get the windsheild out was to pull back the rubber all way along the windsheild...so then i got the idea of putting pencils all around the window, puling back the ruber...i pulled back the rubber with my hand and inserted a pencil between the rubber and the metal of the car...as soon as i got it all in...i added another pencil right next to the last one...and so on...i used like 10 pecils, one next to another...on the top rubber and on the side rubber...
I was worried that it wasnt going to work...but as soon as i pushed the window with my hand from the inside...it poped just right out...hehe...
It felt like magic...if anyone wants to remove there windsheild...i strongly recomend this method...i did not use extreme force...i just pushed it out...very simple and very easy...hehe...
I guess i can say....the pencil is mightier than the sword! hehe....
Thanks a lot...Peace world...
#13 Re: Help removing windsheild....
DatsAndy Posted on: 2008/9/3 1:31
Well done Son. Like i said in one of my replies. You Can Do It. They can handle a bit of force any way matey i have pushed a few in me day and only ever cracked one. Not a Datsun One Thankfully. Ahhh So that's what those Pencil things are used for Now i know why i carried around that little case with my name on it for so long.
#14 Re: Help removing windsheild....
ang94541 Posted on: 2008/9/3 4:15
I thought for sure you'd break it.
Great idea with the pencils. I'll try and remember it.
#15 Re: Help removing windsheild....
1000Coupe Posted on: 2008/9/3 5:01
I have usually done it the same way as datsandy, push with feet and work inside rubber with screwdriver. the rubber outside is a lot stiffer usually than inside.
one thing is that new screens can be laminated, two part with clear film in between. Those can take hardly any force from inside without cracking so need to be cut out.
« 1 (2)
