Re: Can the CA survive without air reg and IACV?
From Sydney, Australia
Yepo. Bypass that plenum warming piping. Run a hose between it.
Posted on: 2008/9/6 12:24
idle air valve is just a bypass valve with a bimetal strip. 10 minutes after ignition is on, the valve slowly closes. Simple device, kind of handy, but not essential in +10c weather.
Posted on: 2008/9/6 12:32
From SE Melbourne
Cool - I'm going to make up a custom elbow to go to the water inlet in the block, and to the turbo water cooling hose. So out just above the lower rad hose, then straight back into the block towards the rear of the motor, with a little T piece off to the turbo cooling.
I was thinking of sending it through the plenum to cool the water down a little, but it wouldn't cool it down much.
Thanks for the advice, has definitely simplified the cooling system.
Posted on: 2008/9/6 13:59
Mildman, Datsunless
From SE Melbourne
I think then you mean this one kegs. I'm going to get rid of it, then reset the TPS.
Posted on: 2008/9/6 14:03
Mildman, Datsunless
From campbelltown (sydney) australia
thanks for clearing it up i removed it last night but forgot to plug the i/c pipe fitting and the engine wouldnt run then i realised after i put it back together it was ok hahaha ohh well.
Posted on: 2008/9/7 2:48
* caution, sunglasses must be worn to view my ca18det *
From SE Melbourne
Ahh do you mean the two holes in the plenum that are exposed once this IACV is removed from the intake manifold?
Posted on: 2008/9/7 10:42
Mildman, Datsunless
yeah ill take some pics of my engine bay tonight before i take my turbo off its leaking exhaust gasket
Posted on: 2008/9/7 10:53
« 1 (2)
