different diff ratio?
From northern 'burbs adelaide
are there any other ratios avaliable for the datsun 1200 utes other than the 4.11? looking for something closer to a 3.5 or 3.6 for highway driving
Posted on: 2008/9/8 7:55
Re: different diff ratio?
From Geelong, Vic
can get 3.7 from 4 speed series 1or 2 bluebirds
Posted on: 2008/9/8 7:58
4 speed Sedans only, 4 speed wagons used the H190 diff in 3,9 to 1 ratio.
Using rear tyres with diameters equal to, or greater than the 574mm of the original 600x12 cross ply will also be an asset.
Posted on: 2008/9/8 8:10
Love your Datsun.
Treat it well.
do these bolt up in the same housings? im running a 15" 195/50 wheel so it has a larger circumference than the original 12" 155/80.
Posted on: 2008/9/8 13:36
All H165 differentials will fit into all H165 rear axle housings. The 1200 ute has a H165 & so does the series 1 & 2 Bluebird.
The 155R12 was not the original tyre size but was in fact the the radial 'option' & at 554mm diameter it's 20mm smaller than the original 600x12 tyre which was 574mm.
The 195/50/15 is 556mm in diameter, just 2mm larger than the stock 'original' 12" tyre size.
Posted on: 2008/9/8 14:02
Love your Datsun.
Treat it well.
From Perth WA
Yes they all bolt in but not all axles are the same. Unless ive pulled a brain fart the old P411 bluebirds ran a H165 with a different axle spline to any other H165.
Also isnt there some sort of a mod(spacers) to adapt a H165 centre into a H145 or is that a 1200 thing due to axle size?
Posted on: 2008/9/8 14:06
Chris...
the 195/50/15 is accually a 576mm diameter tyre so it is running at approx the same size as the original cross ply tyre
Posted on: 2008/9/8 14:20
Actually you are absolutely right about the early, alloy carrier H165's. I must have had a senior moment & forgotten.
The H150 differential shares the mounting gasket with the H145, so it will fit into the h145 housing, however there seems to be a misalignment problem with the centerline of the differential, so a 2mm spacer & a second gasket [one each side of the spacer] should fix that little problem & a wider range of ratios then become available to the 1200 owner.
Posted on: 2008/9/8 19:09
Love your Datsun.
Treat it well.
Yep.
If you had gone to a 205/50/15 on the rear only, they would measure out at 586mm diameter. The slightly wider tread loooks just that little bit more tough from the rear & the extra 10mm of diameter translates to roughly 30mm more traveled distance every time the wheel goes round.
I run 185/60/13's on the front of my 1200 coupe [552mm] & 205/60/13 on the rear [576mm] That way it steers well with no body rub anywhere & the tyres cost less, while the rears fill the wheel arch nicely & maximise my gearing. The big 'n' little look apeals to me & I get a little 'rubber rake' into the bargain which gives it a little bit of attitude.
I have not run the same size tyres front & rear for about 30 years.
Posted on: 2008/9/9 2:16
Love your Datsun.
Treat it well.
From Geelong, Vic
pretty sure all the 195/50/15s i have have stood the same height as the 155 12 on most stock rims
Posted on: 2008/9/9 3:16
