Re: 4 Speed to A14 HELP ???
From New Zealand
to fit a 5 speed into a 1200 you need to fabricate a new gearbox x-member because the mounts are 2-3 inches out. So if you're trying to use a 4 speed and put it back in but still using a custom 5 speed x-member, its going to have the same problem but in reverse. The 56a gearbox bolts up to the a14 engine fine, the 60 4 speed is just stronger (and may have slightly different ratio's?) you need to get a standard 4 speed x-member to bolt it up to the original mounts in the tunnel. Have a look in the wiki under gearboxes, it has a picture of a 4 speed x-member, will help you to idntify what one you're using. This may or may not help....
Posted on: 2008/9/12 21:13
Subject Poster Date
     4 Speed to A14 HELP ??? DatsAndy 2008/9/12 8:25
       Re: 4 Speed to A14 HELP ??? Anonymous 2008/9/12 8:32
         Re: 4 Speed to A14 HELP ??? DatsAndy 2008/9/12 8:34
           Re: 4 Speed to A14 HELP ??? conehead 2008/9/12 8:56
             Re: 4 Speed to A14 HELP ??? DatsAndy 2008/9/12 8:58
               Re: 4 Speed to A14 HELP ??? conehead 2008/9/12 9:10
                 Re: 4 Speed to A14 HELP ??? DatsAndy 2008/9/12 9:17
                   Re: 4 Speed to A14 HELP ??? DatsAndy 2008/9/12 10:08
                     Re: 4 Speed to A14 HELP ??? Dodgeman 2008/9/12 10:31
                       Re: 4 Speed to A14 HELP ??? DatsAndy 2008/9/12 10:34
                         Re: 4 Speed to A14 HELP ??? Anonymous 2008/9/12 13:02
                           Re: 4 Speed to A14 HELP ??? DatsAndy 2008/9/12 13:04
                             Re: 4 Speed to A14 HELP ??? grant76 2008/9/12 21:13
                               Re: 4 Speed to A14 HELP ??? grant76 2008/9/12 21:19
                                 Re: 4 Speed to A14 HELP ??? DatsAndy 2008/9/12 23:20
                                   Re: 4 Speed to A14 HELP ??? pepper 2008/9/13 0:34
                                     Re: 4 Speed to A14 HELP ??? DatsAndy 2008/9/13 3:13
                                       Re: 4 Speed to A14 HELP ??? revhead001 2008/9/13 4:02
                                         Re: 4 Speed to A14 HELP ??? ddgonzal 2008/9/13 5:28
                                           Re: 4 Speed to A14 HELP ??? DatsAndy 2008/9/13 6:53
                                             Re: 4 Speed to A14 HELP ??? revhead001 2008/9/13 10:02
                                               Re: 4 Speed to A14 HELP ??? DatsAndy 2008/9/13 10:46
                                                 Re: 4 Speed to A14 HELP ??? DatsAndy 2008/9/14 5:06
                                                   Re: 4 Speed to A14 HELP ??? supafatto 2008/9/14 8:33
                                                     Re: 4 Speed to A14 HELP ??? supafatto 2008/9/14 8:38
                                                       Re: 4 Speed to A14 HELP ??? DatsAndy 2008/9/14 8:43
