FS: 240K calipers and discs - bolt onto stanza/200b
I've just upgraded my brakes so am selling the old setup.
They are the 256? mm rotors that work with the Stanza/200b strut. I bought the rotors new about 4 years ago but realistically they've only done a few thousand k's.
calipers are in good condition with a set of 95% bendix advance pads.
$200
Posted on: 2008/9/16 12:07
Re: FS: 240K calipers and discs - bolt onto stanza/200b
From Geelong, Vic
253mm rotor
same brake setup as what was first on my car....back in the day
good upgrade over the el crappo stock stanza brakes
Posted on: 2008/9/16 12:12
From SE Melbourne
This is the setup I still have on my coupe, rotors look in pretty good nick too!
Posted on: 2008/9/16 14:38
Mildman, Datsunless
PIGDOG wrote:
....back in the day
And how old are you? 20? Back in your box young whippersnapper. Your still in bloody school for christ sake... back in the day! Sheesh.
Posted on: 2008/9/16 14:41
From Geelong, Vic
hahaha if it was a couple of days ago you would have been wrong about my age
it was a long time ago in the timeline of stuff thats been done to my car....not so long ago in reality though
Posted on: 2008/9/16 15:01
Quite a regular
If my 1200 coupe is still running standard struts and booster, what else do I need to fit this gear?
Posted on: 2008/9/16 22:55
You're gonna need either stanza or 200b struts unfortunately.
Posted on: 2008/9/17 2:46
Quite a regular
To fit stanza struts, I will need stanza control arms, tie rod, tie rod ends....won't I?
Posted on: 2008/9/17 2:57
taken from
stanza struts tech write up
The bits I used:
* early 80's stanza struts with alloy girlock calipers & 245mm solid rotors. (Pre 7/1979 stanzas had the dodgy calipers so steer clear of these)
* Lovell super low stanza springs
* monroe gas shocks (came with the struts but presumably std. stanza ones)
* stanza brake hoses
* Stanza Lower Control Arm's (LCA's)
* 120Y radius rods (tension rods) & sway bar
Posted on: 2008/9/17 3:11
Quite a regular
Thanks Dave. Are you still using the stanza stuts for your next upgrade? What are you putting on them?
Posted on: 2008/9/17 4:20
