#1 Electronic Ignition Coil. Help.
muppet Posted on: 2008/9/21 10:57
Just found a electronic distributer for my turbo A15 and after advice as to what sort of coil I would be best to use. At the moment I'm using a Gt40r coil, but have been told that a Blaster 2 would be a good upgrade.
Don't really want to go to an ugly MSD unit, would like to stick to the round cyclinder type ones if possible.
Any advice much appricated.
#2 Re: Electronic Ignition Coil. Help.
revhead001 Posted on: 2008/9/21 11:09
Surely any sort of electronic dizzy coil should do. Try one off a series 2 bluebird of any blue or black motor commodore 6. (old pushrod motor) They are all pretty much the same. They put out 40KV easily.
#3 Re: Electronic Ignition Coil. Help.
muppet Posted on: 2008/9/21 11:38
Just been looking up the MSD Blaster and these coils put out up to 45Kv, so more volts more spark
#4 Re: Electronic Ignition Coil. Help.
beattie Posted on: 2008/9/21 12:04
There are 2 types of coil. with or without balast resister. Seeing as you said GT40R i would say your still running a resister? Piss it off(join the wires up) and run a high amp non resister coil! Easy!
#5 Re: Electronic Ignition Coil. Help.
fast4motion Posted on: 2008/9/22 8:36
The MSD Blaster 2 is a round cylinder type.
