« 1 2 (3) 4 »
#21 Re: Stock top speed?
revhead001 Posted on: 2008/9/23 21:53
Theres no reason why not. The five speed will definately help it if the engine has enough torque. My old coupe, stock A15 with 14' mags did 160kph all day and didn't budge on hills. It wouldn't rev past 6K but it wouldn't budge if you took your foot off the go pedal.
I had a worked A12 in it before that that I had to nearly 190kph coming home from diggers rest on the calder on a slight downhill with 4 people in the car!
#22 Re: Stock top speed?
sidedraught Posted on: 2008/9/23 22:58
Back in the 80's my bog stock 1200 coupe used to nudge 100 mph (according to the speedo) down the straight on Mona Vale rd heading east from Forrest way.
#23 Re: Stock top speed?
Tyrie Posted on: 2008/9/23 23:32
crzy_1200_ute wrote:
i got my stock ca18det with the stock speedo meter around the gauge 2tiwce :)
Around the gauge twice?
Or off the clock on two seperate occasions?
Standard speedo should have a pin at 0km/h so you can never go around the gauge once let alone twice.
#24 Re: Stock top speed?
benddatsun Posted on: 2008/9/24 3:28
76 b210 /120y tire 175 70 13s buried the 120 speedo and still pulling in 4th with stock A14.
#25 Re: Stock top speed?
revhead001 Posted on: 2008/9/24 6:19
When I drove my van back from Adelaide it was doing 130kph sitting on about 5500rpm. Mabey thats where all my oil went. It used 4 litres by Baccus Marsh.
#26 Re: Stock top speed?
clyons8 Posted on: 2008/9/24 8:20
Around the clock twice?
#27 Re: Stock top speed?
ROConnor Posted on: 2008/9/24 8:30
Had my old ute stock acsept for header/exhaust ruffly 20kph past 160 but it was about 10% out, so ruffly around 160 anyway's
#28 Re: Stock top speed?
crzy_1200_ute Posted on: 2008/9/24 8:48
nah i took my pin out, coz it jamms the needle :)
#29 Re: Stock top speed?
gino_120y Posted on: 2008/9/24 9:25
I've seen 160km/h in my A12 powered 120y
at the time all it had was a free flowing exhaust and an oval port head
(i recon she still had a little more in her aswell, but not much!)
but ever since then, occasionally when i'm travelling just over 100km/h the speedo will jump up another 15-20km/h momentarily.
it
#30 Re: Stock top speed?
revhead001 Posted on: 2008/9/24 9:36
it
« 1 2 (3) 4 »
