wtb:inlet manifold !!!!!!
Not too shy to talk
From smithton tas
hey as the title states i need an inlet manifold for my a12 engine and to fit my twin solex 40mm carbis side draught !!!!!
Posted on: 2008/9/26 14:07
Re: wtb:inlet manifold !!!!!!
So you are after the dual sidedraught manifold?
They sell them at SW
Twin solex's? Same as the ones that I'm running.
EDIT: Actually from memory there might be a slight issue with fitting the carbs on the SW manifold, I can't remember clearly but I think the throttle shafts touched before the bolt-holes lined up.
Posted on: 2008/9/27 7:15
Not too shy to talk
From smithton tas
yeh i am its dual and do you know if you could get me one ??????
Posted on: 2008/9/27 13:33
From Florida, USA
You mean dual 40mm side draft like a weber? I have a manifold that would fit an A12 that I would sell but I'm not sure what it would take to ship it from here to there.
Posted on: 2008/9/27 14:37
Well it's not too hard to find yourself. All you have to do is mention the make of your carburettors, that they are going on an A12 with round (?) ports.
Google it.
Ring swmotorsport and ask if their manifolds take the solex's. I can't remember clearly enough.
If you really do get stuck then I have one here.
Posted on: 2008/9/28 0:07
Not too shy to talk
From smithton tas
yeh it is but dual 40mm solexes just like a webber ,how much would you be looking for ,and could you find out how much it would be to post it ??????
Posted on: 2008/9/28 0:40
Okay, first you need to confirm whether you have a round or oval port head.
If it is the original head then you nee a round port manifold. If it is a GX, A14, A15 head then I can help you with the new manifold that I have here.
Let me know what you have.
Posted on: 2008/9/28 1:26
Not too shy to talk
From smithton tas
yeh its round port !!!!
Posted on: 2008/9/28 9:04
I think that you will find that new manifolds of the type that you want are NLA. Single Weber/DelOrto/Solex ones seem to be around & for street use these are a better choice anyway.
Posted on: 2008/9/28 9:46
Love your Datsun.
Treat it well.
Not too shy to talk
From smithton tas
well do you know where i could get one then ?????????
Posted on: 2008/9/28 11:11
