« 1 (2)
Re: ca18det using LPG?
Quite a regular
No I didn't modify the spark timing. The Cordia being turbo ran a knock sensor as standard which remains operational.
Posted on: 2008/9/20 5:19
From Rosewood, QLD
i have no experience at all with this topic and im just going on what ive heard from other people but ive heard that boosted cars run really well on lpg when set up correctly such as tosser has described
Posted on: 2008/9/20 11:40
1971 B110 sedan project.
2012 Nissan Micra daily.
From Newcastle
im not 100% sure on what conponents im going to use theirs a guy that does gas injections near me and we chatted for a while when im ready to do the motor then we will talk about it indepth im gathering info off these posts to . . and extra info that people can tel me would be great
Posted on: 2008/9/20 11:56
From the central coast, nsw
i do all lpg gas installs!! direct injection is the only way to do it! n u get $2000 gov rebate! ive gained kw readings on the dyno after installed on gas
Posted on: 2008/9/25 14:06
From Brisbane
So if you do lpg conversions, have you ever done a turbo vehicle? What's the total cost with the rebate? Would be great to have more info.
All turbo cars need at least a piggyback computer to alter timing on lpg. I've read it's very expensive.
I'm still keen to see tossers pics with some instructions on how he did it with the venturi setup. That way everyone can compare the pros and cons of each.
Posted on: 2008/9/26 0:52
Quite a regular
Hi guys, sorry I haven't got around to sorting thru my box of photos yet. The systems I suggested on this thread are for those who can't afford an injected system and are happy to forgo max performance to save some bucks.
For the turbo set-up I did it all myself. I used a secondhand Landi system from a 3.9 EA Fairmont. Even the tank fit! This system has the Landi control box which reads info from an O2 sensor which I had to install into the exhaust system. I did find the venturi from this system too restrictive and ended up running the turbo with no waste-gate at all to compensate. This car was amazing, awesome economy and could pull 200 easy.
On the supercharged 4AZGE car I used a huge secondhand venturi from a wrecker and the rest was pretty much new. I did some of the install but the garage that was certifying it did the most. They were really good and recommended which converter to run etc etc. This car was straight gas and had heaps of lowdown and midrange but ran out of legs at 160. Looking back maybe the converter was too small. It was also suprizingly thirsty for a small motor but it did demand to be driven hard.
Posted on: 2008/9/26 3:21
From Brisbane
Hey,
I like the sound of your turbo system. So did the oxygen sensor from the Landi replace the one used by the car's computer, or did you have two in there?
Did you install the venturi just before the intake plenum/ just after the intercooler?
I guess you never had it registered? Would be great if this system was legal, don't see why not
Posted on: 2008/9/29 4:46
« 1 (2)
