manifold questions
From northern 'burbs adelaide
just wondering what the performance issues would be if i took the plastic spacer out from under the carby with the aluminium tube in it and replaced it with one that doesnt have a tube in it
Posted on: 2008/9/29 8:49
Re: manifold questions
From Melbourne, Oz
Is this under a stock carby or under a weber 32/36 or similer?
Posted on: 2008/9/29 8:51
"I hav achieved wood"
Aluminium pipe??!?
I know what you're talking about but I haven't ever seen one with an aluminium pipe. If I recall you were after a stock carby.
I wouldn't expect any power loss.
Maybe pop up a picture.
Posted on: 2008/9/29 8:58
its under a stock carby ... ill post a pic up tonight
Posted on: 2008/9/29 21:52
Yes, that will change the performance ... for the worse. You won't notice much change though, more likely to notice your fuel costs go up a bit.
Posted on: 2008/9/30 3:52
well starting cold has gone out the door and it runs like a bag of s**t now. but as for fuel economy i'm getting the best i've had since i bought the car. ah well a ca will fit in there quite nicely soon enough
Posted on: 2008/9/30 21:50
From Charlotte NC USA
make sure two things are true
1. you have power and ground at the choke
2. that the choke is adjusted correctly
Posted on: 2008/9/30 23:23
Phil (aka nutcase)
I have C.L.W.E.A.
Can't Leave Well Enough Alone
120y exelant clone gone :(
she's manual choke mate
Posted on: 2008/10/1 10:44
here what the original one looks like
Posted on: 2008/10/1 11:01
From Townsville, Qld
Well I'll be danged, none of mine have that. What it does though is allow the mixture to speed up before it's mixed and distributed to the cylinders, I would like to make a tube suitable for my 32\36
Posted on: 2008/10/1 12:15
