Browsing this Thread:
1 Anonymous Users
Sparco seats problem |
From Portugal
How can i install a pair of sparco seats in my 2 120y without removing the original seats support? any ideas? And how can i do to use the back seat? is a 2 doors 120y
Posted on: 2008/9/30 20:48
Re: Sparco seats problem |
From Canberra
Depending what year model 120Y you have you may have to remove the brackets closest to the tunnel and remount them the same height has the ones near the doors.
Forget carrying back seat passengers with fixed buckets haha
Posted on: 2008/9/30 21:57
3mm stainless adaptor plate or weld up a square braket to suit I have bolted the 3mm stainless sheet under the seats then bolted the seat runners to it. You do need to keep the rails as it wont pass rego with out movment mine moves about 2cm but thats all it needs
Posted on: 2008/10/1 2:10
Don't You Just Love Owning a Road Registered GOKART
From Canberra
Quote: Homer wrote: 3mm stainless adaptor plate or weld up a square braket to suit I have bolted the 3mm stainless sheet under the seats then bolted the seat runners to it. You do need to keep the rails as it wont pass rego with out movment mine moves about 2cm but thats all it needs
with a late model 120Y you actually need to remove the brackets that the rails bolt to (on the floor) or else the seat will hit the roof.
Posted on: 2008/10/1 3:19
From Portugal
in my 1977 120y i dont have to remove the brackets , the seat fits well on top of them. but i have 6cm diference between them
Posted on: 2008/10/1 7:48
From Canberra
6cm difference? as in one rail sits 6cm higher than the other? If so, are you sure the seat isnt rediculously high for comfortable driving?
Posted on: 2008/10/1 8:30
From Portugal
yes the rail is 6cm diferent from the other,
it gives-me a good driving position, and i think all the 120y are like mine.
Posted on: 2008/10/1 18:54
From Canberra
fair enough, early 120Ys had rails the same height (my '74 does)
Posted on: 2008/10/1 23:53
