#1 manifold questions
aidaniel Posted on: 2008/9/29 8:49
just wondering what the performance issues would be if i took the plastic spacer out from under the carby with the aluminium tube in it and replaced it with one that doesnt have a tube in it
#2 Re: manifold questions
ROConnor Posted on: 2008/9/29 8:51
Is this under a stock carby or under a weber 32/36 or similer?
#3 Re: manifold questions
clyons8 Posted on: 2008/9/29 8:58
Aluminium pipe??!?
I know what you're talking about but I haven't ever seen one with an aluminium pipe. If I recall you were after a stock carby.
I wouldn't expect any power loss.
Maybe pop up a picture.
#4 Re: manifold questions
aidaniel Posted on: 2008/9/29 21:52
its under a stock carby ... ill post a pic up tonight
#5 Re: manifold questions
ddgonzal Posted on: 2008/9/30 3:52
Yes, that will change the performance ... for the worse. You won't notice much change though, more likely to notice your fuel costs go up a bit.
#6 Re: manifold questions
aidaniel Posted on: 2008/9/30 21:50
well starting cold has gone out the door and it runs like a bag of s**t now. but as for fuel economy i'm getting the best i've had since i bought the car. ah well a ca will fit in there quite nicely soon enough
#7 Re: manifold questions
nutcase Posted on: 2008/9/30 23:23
make sure two things are true
1. you have power and ground at the choke
2. that the choke is adjusted correctly
#8 Re: manifold questions
aidaniel Posted on: 2008/10/1 10:44
she's manual choke mate
#9 Re: manifold questions
aidaniel Posted on: 2008/10/1 11:01
here what the original one looks like
#10 Re: manifold questions
LittleFireyOne Posted on: 2008/10/1 12:15
Well I'll be danged, none of mine have that. What it does though is allow the mixture to speed up before it's mixed and distributed to the cylinders, I would like to make a tube suitable for my 32\36
