#1 Motorcycle Carbs
Bandit_blues Posted on: 2008/10/1 11:13
Can someone tell me from which bike, or displacement is better for a standard A12 engine?
#2 Re: Motorcycle Carbs
ROConnor Posted on: 2008/10/1 11:21
Somthing of a 1000cc motor would be adiquate as motorbike motor's are at a much higher state of tune out of the factory, but if your gona go all out with the motor somthing of a simerly sized 1200cc bike would be better.
#3 Re: Motorcycle Carbs
Bandit_blues Posted on: 2008/10/1 11:27
I was thinking about the carbs because is easy for a EFI conversion
#4 Re: Motorcycle Carbs
lampy Posted on: 2008/10/1 11:29
i am using a set of carbs off a cbr1000 for my a12. Just about got the manifold made. Will post picks when done.
also going to use cb900 carbs for my a10 in the 1000
#5 Re: Motorcycle Carbs
LAGWAGON Posted on: 2008/10/1 11:34
yeah i'm doing the same. ideally i think you want something around 34mm but they are harder to find and more expensive than the 38 - 40 mm ones. I'm currently waiting for my 07 suzuki gsxr 600 setup from the US. cost me $135 delivered
#6 Re: Motorcycle Carbs
Dodgeman Posted on: 2008/10/1 11:35
Puting four carbs on a 'standard' 1200 or A12 is not really such a good idea unless you also fit a cam that will take advantage of the induction's ability to feed it some fuel.
With a standard cam the engine will simply be overcarbureted.
#7 Re: Motorcycle Carbs
Bandit_blues Posted on: 2008/10/1 11:42
What about the fuel pump? what mods are needed?
#8 Re: Motorcycle Carbs
Bandit_blues Posted on: 2008/10/1 11:46
Please send us some pics Lampy, i`m getting a Datsun 100A tomorrow for my wife, and i`m thinking of convert it to fuel injection through a bike carb setup.
#9 Re: Motorcycle Carbs
Retal052 Posted on: 2008/10/1 12:13
I have fuel injection off a YZF-R6 yamaha using standard injectors (motorbike) for my A14 w/cam.
I picked up the bodies on ebay for $140 + postage
used my own computer (haltech f7) and ran a return line.
Used a surge tank fed by existing mech. fuel pump to a VL turbo EFI pump
#10 Re: Motorcycle Carbs
Bandit_blues Posted on: 2008/10/1 12:50
I was just wondering, if i had that YZF fuel injection setup so i could easily tune with a system like megasquirt or someting similar, would i need a cam change?
