Re: What clutch to run with A12/A15 + FS5W60L?
First have a look at your throwout bearing sleeves. If you have a long and a short type then you have your choice between the 2 flywheels. If they are the same weight then the decision is 6 <> 1/2 dozen. Personally I would use the A12 flywheel as the mass of the flywheel is closer to the crankshaft. With that use the longer of the 2 throwout sleeves. (i'm pretty sure you have both) Probably a 1200 ute clutch should do the job nicely for street use.
Posted on: 2008/10/7 21:00
Subject Poster Date
     What clutch to run with A12/A15 + FS5W60L? gino_120y 2008/10/7 12:03
       Re: What clutch to run with A12/A15 + FS5W60L? revhead001 2008/10/7 21:00
         Re: What clutch to run with A12/A15 + FS5W60L? Anonymous 2008/10/7 23:48
           Re: What clutch to run with A12/A15 + FS5W60L? gino_120y 2008/10/8 6:59
             Re: What clutch to run with A12/A15 + FS5W60L? PIGDOG 2008/10/8 7:21
               Re: What clutch to run with A12/A15 + FS5W60L? Anonymous 2008/10/8 9:09
                 Re: What clutch to run with A12/A15 + FS5W60L? b310gx 2008/10/9 1:16
                   Re: What clutch to run with A12/A15 + FS5W60L? Anonymous 2008/10/9 1:33
                     Re: What clutch to run with A12/A15 + FS5W60L? PIGDOG 2008/10/9 6:03
                       Re: What clutch to run with A12/A15 + FS5W60L? gino_120y 2008/10/9 6:20
                         Re: What clutch to run with A12/A15 + FS5W60L? woody 2008/10/10 12:37
                           Re: What clutch to run with A12/A15 + FS5W60L? teflon 2008/10/11 0:06
                             Re: What clutch to run with A12/A15 + FS5W60L? Dundee1000 2008/10/11 0:53
