Re: help req for sc14 supercharger setup
Quite a regular
You dont need to run oil to it. Modern superchargers like on the 4AGZE are teflon coated inside. Take a look. It will be black and slippery inside. Make sure this coating is not stuffed or you will have a nice door-stop. If you are sucking through a carb you will not need the breather pipes, just block them off. As for the 12V power supply to the electric clutch, just rig up a switch on the dash. This is handy just incase the supercharger sh$ts itself you can turn it off and keep driving.
Posted on: 2008/10/8 1:39
Quite a regular
Your biggest problem is mounting the supercharger. Somewhere in line with the pulleys with a facility to take-up the slack in the belt.You will need to put a multi-ribbed belt pulley on your crank. That adjustment mechanism that came with the supercharger looks too bulky to me. I would modify an alternator bracket and mount it there. As for the intake manifold, I would get a dual Weber manifold and weld on a long piece of pipe as your plenum and the rest is easy. Also a V8 airfilter box to allow easy flow.
Posted on: 2008/10/8 1:48
From Christchurch NZ
I just blocked off all those hoses on my set up.
Posted on: 2008/10/8 8:12
Forced Induction!
thanks guy for your help i understand alot better now. going to give her a clean and refresh vac blocks and new lock nuts and gaskits custom i guess, hope to pick up a donk drop it off 2 a mate and when shes on the road drop new motor and charger in asap. not to far away another 2 months till she'll be goin should have been sooner but decided to respray.
Posted on: 2008/10/8 9:25
Car free
From Ballarat Victoria
There is oil in the gear case at the end, there is usually a screw in dipstick to check fill level.
Posted on: 2008/10/8 10:38
VIC DYNO HIRE
if so wat oil would u use. ill take a look and see if there is one
ta nick
newer looking pic
Posted on: 2008/10/8 10:50
Car free
From Perth
Have just put a sc14 on an A15 in my Morris Minor and found that the main problem was too much boost. I did have a 135mm pulley on the crankshaft which was putting out 11psi, now I am down to to 115mm pulley which seems better but still have to retard the timming as it was still pinging at full accetoration. May try a smaller pulley in the near future, I hear 4-6 pounds boost is about best.
Posted on: 2008/10/9 1:59
Glen
Morris Minor, Datsun 1500, Supercharged, 5 speed.
They run a special toyota oil. It smells like silicon, and costs sh1tloads.
Posted on: 2008/10/9 8:04
Forced Induction!
From Melbourne, Australia
what are you doing for a carby fella? did you get one with the kit?
Posted on: 2008/10/9 8:34
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
thanks ill look at the pully size and find out how big it is. also a14forced where did u get the oil dont care wat it costs if it needs it ill get it. 1200rallycar i have not got a carbi as yet but the bloke i bought the setup from is sending it to me by the looks of things it had a 32/36dgav on it why u ask??
Posted on: 2008/10/9 10:37
Car free
« 1 (2) 3 4 5 »
