« 1 2 3 (4) 5 »
#31 Re: multi coil ignition a15
tiagosainhas Posted on: 2008/10/15 15:13
hi guys, i'm portuguese and i have the same project to my car, i have a citroen bx 87 (it's not a datsun) but i need to tune up my ignition system to a multiple coils systems 2 or 4 coils but i need to konw how i construct one electronic distributor. i think if i use a hall sensor to determinate the tdc i need to use another sensor to determinate the point each spark, sorry the english.... maybe another sensor in flywheel? i hope you understant....
#32 Re: multi coil ignition a15
Retal052 Posted on: 2008/10/16 10:58
Update on my setup guys,
I have got all the gear to setup. bought the EDIS kit from ebay $100 bought the mjlj kit and built myself bout $150. and I gotta wire it all up and weld the 36-1 toothed wheel to the pulley. will post piccys when done!! hoping this weekend :)
#33 Re: multi coil ignition a15
1200rallycar Posted on: 2008/10/16 11:32
looks good, gonna have to get me an EDIS i already have megasquirt, this megajolt looks very similar
#34 Re: multi coil ignition a15
frankthedolphintrainer Posted on: 2008/10/16 11:41
going back a few post to the picture reuby put up... i took that photo and its the setup from the that 200somthing kw a12 from the goldy, the guy that works at head works.
and what the edis thing your talking about?
#35 Re: multi coil ignition a15
LONGBROW Posted on: 2008/10/16 12:02
Yes please keep us posted. I am very interested.
#36 Re: multi coil ignition a15
D Posted on: 2008/10/16 12:30
Someone make a kit and youll be in business. It could be used on many engines.
#37 Re: multi coil ignition a15
datto1000wagon Posted on: 2008/10/16 12:46
have a look in my album for a custom made pulley im making to hold my 36-1 trigger wheel
#38 Re: multi coil ignition a15
Retal052 Posted on: 2008/10/17 13:17
I would make a kit with the wheel and everything that you need but you would need access to an endless junkyard spares. any of the edis 4cyl stuff is from America. I could build the Kit for you guys (well guys in perth anyways).
As for what the EDIS system is. Well the EDIS module reads the toothed wheel, and gives a static 10 degrees advance across all rev ranges/load. The MJLJ does the rest using the PIP/SAW wires. yes it is like the megasquirt, but only for spark. I already have a fuel only computer for my injection.
And yes it will work on any engine setup. I have heard of a single cyl setup using EDIS.
Installing this weekend!! will post up sum piccys!
#39 Re: multi coil ignition a15
dazza1200 Posted on: 2008/10/17 13:43
ive got a 4g63 mits cas you can have
and it seems your in serpy!
and it was you i saw the other night!
2 1200 coupes within 1k of each other
dazza
im not bad w/ a multimeter/soldering iron too
#40 Re: multi coil ignition a15
D Posted on: 2008/10/17 14:33
the MJL is the issue can only get it from the states for big USD for the assembled item. Compared to Electromotive kit its way cheaper but would be nice to have something local.
« 1 2 3 (4) 5 »
