Re: 60 series 5 into 1000 need help
From Darwin NT
not sure about coupe but i think youd be able to bash out a little section for the switch to fit in
Posted on: 2008/10/15 11:07
current project 4x4 patrol...
From Perth Western Australia
here's what was needed for the 5 speed conversion (it was a while ago so if i miss anything i'm sorry)
1. tunnel massaging - not much just enough to clear the clutch fork as it's a little higher than the b10 box. it will work tho don't be afraid to give the tunnel a good whack!
also a little indent was needed for the reverse switch
2. original gearbox mounts - i took mine out it made it alot easier to install and remove the 5 speed.
3. Rear gearbox mount - i adapted a sunny gearbox mount and made it wider incorporating plates to have the mount bolt onto the floor pan in the footwells I also put plates on the inside to give it some strength.
If you know anyone that can weld or if you can do a decent job this is easy.
4. clutch cable had to be altered - I used an old cable from a 1200 for a while which was spaced out at the firewall with washers but once i had the lenght right I had a new cable made up.
5. tailshaft - here's where things get a bit hazy cant remeber if i had to have it shortened don't think i did
It took me about a week of after hours tinkering to get it in a driving but well worth it. hope i didn't miss anyhting important
good luck!
Posted on: 2008/10/21 2:25
Datsun 1000 it's
All-round Action!
Thou Coupe worked A14 twin bbq's
From Melbourne vic
Good stuff dude, helpful info
cheers Dean
Posted on: 2008/10/21 2:38
:Impressive, will it fly?
:Yes, if i fold it here and here
:Nice
« 1 2 (3)
