Browsing this Thread:
Can someone point me to the Weber kit for a sunny coupe
From PHILLY USA
I am trying to track down a weber for my car and keep finding they are dated 1974 on up. Well considering they didnt make the car here in 1974 what carb would I buy for my car? Best I could find was kit K8624 or K624? If you can point me in the right direction that would be great.
Posted on: 2008/10/23 3:34
Re: Can someone point me to the Weber kit for a sunny coupe
From Melbourne vic
I'm not sure what you mean, a fitting kit, a
rebuild kit A carb and manifold kit?? Why does
the comparison of year of your car /carb matter? etc etc
Posted on: 2008/10/23 5:40
:Impressive, will it fly?
:Yes, if i fold it here and here
:Nice
From PHILLY USA
The whole kit to switch from the Hitachi to a Weber meaning the carb, linkage, adapter plate ect.... I know redline makes them but the kits must be mis numbered or something for US models. I just want to make sure I get the right one.
Thanks
Posted on: 2008/10/24 1:32
From sydney
As all the standard carbs are interchangable, I would think that the redline kit should be pretty much universal for all the Sunny family.
Posted on: 2008/10/24 1:34
From Las Vegas USA
Pierce Manifold has the part number for the 1200 / LB110 on adapter plate their site. They also list a complete kit. The standard Weber 32/36 DGEV will do the trick. Check the classifieds for your local SCCA region or vintage racers...........there is always someone going from the 32/36 to side draught carbs. I once used a DGEV carb off a 510 on a street 1200 and it went just fine albeit a touch rich.
Tom
Posted on: 2008/10/24 2:17
From PHILLY USA
Will THIS ONE <--click here Work?
Posted on: 2008/10/24 2:44
From Las Vegas USA
It should but make sure you get the dimensions for the 4 counter sunk holes in the adapter plate...........if I remember correctly those replace the studs in the manifold. You can always get a base gasket for the carb draw a quick template and fax it over to them but it looks correct.
Tom
Posted on: 2008/10/24 2:57
From PHILLY USA
Ok I understand, the only reason I ask is. I emailed them asking for the specific kit and they told me it is $329.99..... About $40 more then this kit. I didnt understand why there would be a price difference if they were interchangeable.
Posted on: 2008/10/24 3:06
From PHILLY USA
I found the difference
The correct gasket here
Datsun 1200 Coupe in kit K624
And the 510 kit here
K662 510 kit
Posted on: 2008/10/24 3:35
