Brake Upgrade
From Murray Bridge, SA
hey
Wondering if some 1 can help me as to wat front struts and disk brake upgrade to make. they need to fit a 15inch x 6.5 Wheel with 195/50R15 Tyres, will just a bolt on 120y struts do the job or do i need stanza 1s or something else?
pretty sure i can get 120y 1s from u pull it.
Posted on: 2008/10/30 12:26
Cars:
1973 Datsun 1200 sedan (Project)
19?? Datsun 1200 sedan (Parts Car)
A12 crankin
Re: Brake Upgrade
From Armidale N.S.W
PM PIGDOG He would know.
Posted on: 2008/10/30 13:20
73 1200 wagon SOLD
Re: Brake Upgrade
From Brisvegas, oz
it all depends on how much power you mighty machine has. the 120y standards are quite pathetic but better than drums and the stanza is a good cheap upgrade. you can alaso buy a adaptor to fit ca18 disks and calipers to the standard 1200 strut or 120y strut
Posted on: 2008/10/30 20:21
www.camerasplus.com.au
Re: Brake Upgrade
From Geelong, Vic
depends on the offset of the wheel mainly in your case...as you can adapt pretty much anything to anything if you are keen enough
120y and 1200 struts will require a 0 or negative offset to fit the wheel in due to the different stub axle angle. where as stanza struts and other bigger struts a +20-25ish offset should fit well and still just be in the guards
Posted on: 2008/10/31 1:53
Re: Brake Upgrade
hey
thanks for your help fellas, i just looked at my wheels and it has got ET38 stamped on it. 38mm offset.
im thinking i may need stanza stuts or use spacers on 120y 1s.
Posted on: 2008/10/31 12:12
Cars:
A12 crankin
Re: Brake Upgrade
if the are +38 offset u WILL to wat i no need to run spacers. to fit rear as well trx rims need small spacer to offset rim as they sit very close to leaf springs!!
hope this helps
Posted on: 2008/10/31 12:23
Car free
Re: Brake Upgrade
cheers mate, im running small spacers on the rear to stop them hitting the leafs, but yer, if any1 knows if they will fit on a 120y front end that would help as im lookin for a quick change over. im only running a stock engine so they should be good enough to pull it up i think.
Posted on: 2008/10/31 13:44
Cars:
A12 crankin
Re: Brake Upgrade
From Geelong, Vic
in short, without spacers they wont fit on any thing except for maybe r31 struts
will need decent sized spacers for 120y struts 20-30mm at a guess, and probably 15mm spacers to clear stanza struts
just going off the fact that r30 rims are 15x6 and about +20-25mm offset and dont clear stanza struts by a whole heap
Posted on: 2008/11/1 3:00
Re: Brake Upgrade
hey thanks for all ur help.
i might stick with my bluebird stuts as i know the wheels will go on there.
Posted on: 2008/11/2 1:27
Cars:
A12 crankin
Re: Brake Upgrade
From Geelong, Vic
that offset fits on bluebird struts? sure someone hasnt swapped them for r31 struts at some point? basicly the same strut but with shorter inserts and different stub axle angle
coz if they fit on bluebird struts then they should fit on stanza, 200b, 180b etc struts
Posted on: 2008/11/2 6:44
