Re: Brake Upgrade
From Murray Bridge, SA
yer they do with a small 5mm spacer..... heres the story- i went to the local wreakers looking for a 120y or stanza but they didnt have any so the guy said wat about bluebird struts, they might fit, so i tryed on the mag and they did so, i ended up with they whole bluebird trx for $200.
they could be r31 stuts for all i know.
is there a measurement i can take to find out?
Posted on: 2008/11/2 7:14
Cars:
1973 Datsun 1200 sedan (Project)
19?? Datsun 1200 sedan (Parts Car)
A12 crankin
Re: Brake Upgrade
not sure if u can tell by a pic but herethey are anyway
Posted on: 2008/11/2 7:16
Cars:
A12 crankin
Re: Brake Upgrade
From Geelong, Vic
nah they are bluebird struts...would have thought it would take more than a 5mm spacer to clear
but if you stick with the bluebird struts you should get some r31 front brakes and put them on, disc/hub and caliper bolt straight on and they are vented discs
Posted on: 2008/11/2 8:50
Re: Brake Upgrade
yer a 5mm spacer clears it just fine.....
im gonna run 4 wheel disks using the trx rears so the stock bluebird 1s will prob do the job
and thanks again for all ur help
Posted on: 2008/11/2 11:20
Cars:
A12 crankin
Re: Brake Upgrade
From Geelong, Vic
r31 fronts will do the job better
Posted on: 2008/11/3 3:22
« 1 (2)
