Things for sale holley, dells and SUS 2inches 50.1mm each
Holley twin barrel 7448 carburettor - manual choke, flows 350cfm all in excellent condition
$160 plus postage or pick up - still available
pic is for reference only mine is original light golden color not silver.
Free to good home - still available
Feroza motor HD 1.6 ohc 16v plus complete HC 1.3 16v
This motor is all alloy and can make 125hp with simple Detomase grind or over 170hp with Race Rally grind and correct exhaust system as run by MRT on their 3 time 2ltr and under Australia Rally Championships.
I also have the gearbox bellhousing (cable operated) to adapt to a rwd gearbox and just needs edis-4 Module for running no distributor on the rear ect. Something different all alloy 25kg lighter than A14.
All items are posted Australia wide with excellent packaging and registered delivery included for $20
Posted on: 2008/11/5 6:08
Re: Things for sale inc. twin spot calipers and 32/36 weber
Also available are 2inch SUS to suit L series or A14/15 big power motor. Must extrude hone your twin sus manifold or match port.
Better option than single Weber DCOE45 45mm sidedraft.
2inches equals 50.1mm each so equal to 50mm weber but with better economy and no expensive jets to play with.
$200
Posted on: 2008/11/6 8:39
Regarding the calipers, what does the Twin Spot reference mean?
I never understood this.
Just put the first coat of clear on the engine bay D and I've found a big dent on the front apron. Some clown has bumped it. Not f'in happy.
Posted on: 2008/11/6 8:43
From Geelong, Vic
means twin piston caliper
Posted on: 2008/11/6 8:47
Please note
The twin sus with their Rover manifold will not bolt up to an A12.
The calipers will not bolt up to any front end by wishful thinking
The Weber and Holleys are not bolt on items unless you have an adapter.
I dont have an A series twin sus manifold
I was never voted sexiest man alive by Cleo magazine.
Posted on: 2008/11/6 11:04
